So, after watching all these new workflow videos, it seems Brute Force and Light Cache is the recommended way to render. Currently, I have an exterior scene with 3000 trees, 1000’s of flowers, with a lot of displacement. My question is, are you using BR+LC for these kinds of scenes, or are you having better success with IRR+LC, like in the old days?
These ‘new workflow videos’ are basing the use of BF on the assumption that render time is irrelevant.
I think that they would not agree. The pitch is, it is faster and better.
isn’t that in comparison to the universal method? it’s significantly faster than working like that used to be, but I still don’t think it’s the fastest method (and we’re yet to install vray3 for me to test)
The point is that it’s quick to get going and you can trust it (without it taking anywhere near as long as BF/BF in 1.5), rather than testing over and over.
I guess it is a predictable workflow, but for my exteriors with lots of vegetation, I haven’t gotten it to be a good solution. But, I have been told, that I must be doing it wrong ![]()
If you’d watched the Grant Warwick videos you would have heard him mention numerous times that render times are still higher but for the type of work he’s aiming his tutorials at, this is a trade-off worth making.
…as I recall the method it’s mainly for interior and not exterior because of all the vegetation - but I could be wrong.
Works for me and seems to be supported by Solidrocks.
I believe it’s more to do with the fact that IR works well with exterior scenes due to the abundance of light available but darker interiors usually fall prey to IR splotchiness. BF doesn’t fall prey to this but instead has inherently more noise.
If you’re using this ‘new method’, it’s so easy you’d be probably be wise to ditch SR. I don’t believe SR is intuitive enough to work correctly in-line with the method outlined here: http://www.cggallery.com/tutorials/vray\_optimization/
I’m trying to push a large scene through using BF+LC, but it’s not going well.
faster than the old BF is my interpretation, although I haven’t tested it as yet.
Lots of VRayProxy trees with Light Cache can ramp up memory usage in my experience.
What’s your secondary bounce?
In my opinion, exteriors with 3d grass, trees, displacement, etc… BF+LC it isn’t a good idea.
Because LC is good for complex GI situation. and outdoor rendering isn’t a complex for GI.
In exterior rendering, usually, we have 2-3 light bounces. So, why to use LC?
Also, LC can use a lot of memory in this situation (a lot of geometry)
BF+BF with 2-3 bounce (maybe post noise reduction) it could be a good solution IMO.
Also, in the new VRay 3.0 BF is very fast now.
IR/LC for interiors, IR/LC for exteriors.
I’ll test BF and consider moving when we get 3.0 installed, but there’s a vast speed difference between them as it is and i’m not entirely sure the improvements will close the gap.
I tried BF/BF last night, and I woke up to 27 more hours to go! I stayed steadfast, and did some trouble shooting and removed my Multiscatter trees, and voila! without Multiscatter, and just as many trees hand scattered, it rendered in 45 minutes. How can a plugin make things go so horribly wrong?
also, I turned blur off of all my materials, and for the trees and bushes I turned the max depth to 1, but I did this early on.
With BF+BF+Multiscatter 27 hours? Mmm… look at the CPU usage, please. Is it 100%?
I never get above 10% cpu usage using multiscatter no matter where the buckets are. When it’s first created it works fine but after a while of doing other things (not touching scatter) it’ll drop to single core use for the entire scene. it’s a broken piece of shit and any old scene with it in i replace with forest pro now.
