When i reopen my files, extra texture element has lost its name that i given to it, and if i have multiple extratexture elements the first one overrides the rest.
Is this a known issue?
thanks
thanks
Have you switched off the auto update name option in the parameters?
Never seen that actually! I ll check it 2morrow, but seems like the answer here! Thank a lot mate, it kept ruining my renders for a while now !!
It’s a nice feature if you name your maps properly, as it basically names it according to the map.
Ye although imo, it should be off by default since u rename all elements in same tab makes it very easy to miss this button. I was assuming that its a bug since all elements dont switch name and never occured to me that since i put maps in there it can work like this.
In any case glad i solved this ![]()
