Extractling Beauty from VRIMG files in batch
Is it possible to extract the Beauty pass from a VRIMG in a batch process? I’ve run an animation and stupidly had bloom and glare turned off - not a problem with the new batch image processor, except that each frame contains quite a few passes and as such I’m seeing a lot of network traffic. It would be great if I could extract just the beuty and then batch process that with the bloom and glare setting from my .vfbl layers file.
or if batch processing accepted EXRs then I could extract the beauty pass with VRIMG2EXR and then glare those.
EXR support for the batch image processing is already in the works.
Apart from that - would adding an option in the batch processing tool to only write the final effectsResult/Beauty and skip other elements work for you ?
And also if you have other ideas for improvement to the batch processing tool - they are welcome :slight_smile:
Yavor
Great news! and absolutely, I see having that option to easily run a few variants of bloom/glare settings could be useful for animators.
Actually that potentially makes the VFB a great grading tool for sequences too.
Oh! one more thing, having a submitter plugin for deadline as with VRIMG2EXR and Denoise would be great. Then you could que the whole process from render - to denoise and finally grading/ lighting options.
Any progress on batch processing accepting EXR? I’ve recently run a 3000 frame animation and having to retain all the VRIMGs in case I need to tweak glare is taking a massive amount of disc space.
