Hi everyone! (sorry, I have a bad english).
I’m Alexis from Spain and I’m desesperate with the next problem:
I had a problem one month ago, I was working with a scene, and everything work fine, after windows update, the file need like… 1 hour for open? sometimes more, in the task manager needed 100% cpu process and massive ram. I could back in the windows update and worked again… but now I have the same problem and I can’t remove the update.
Some informations:
-If uninstall corona render, the scene is opened very fast.
-I’m not using xref file, isn’t a complex file, and only one camera animation, not more animations layers.
-If I remove all materials in the scene (apply standar material without any textured for example to all geometry), the scene open fast. So
-I’m using last version of corona and 3dsmax 2021.
Thanks a lot for your help
