I upgraded to Viz 2007. Everything was working fine, but the other day I started getting errors when loading Viz
I am getting errors "vrayplane60 and vrayplane failed to initialize Error Code 126 - the specified module could not be found…
Ive tried reinstalling Vray but the errors dont seem to go away.
What should I do?
Ive posted another problem I have in the General section - about a texture map not loading. I also have Forrest Pro plugin running and the trees dont show up either. When going thru the passes, they sometimes start to show, them BOOM they go away…
For some reason which is not quite clear, 3dsmax sometimes re-orders the lines in the plugin.ini file, which causes some V-Ray specific plugins to fail to load. In that case, open the plugin.ini file and move the additional v-ray plugins path to the end of the plugin directories list and these errors should go away.
There might be multiple plugin.ini files on your computer (one in the 3ds max root folder, and others in the “Documents and Settings”/“Users” folder respectively for Windows XP/Vista). Check that all of them contain the same thing.
I just un-installed the old beta of Phoenix and have the 126 error code now aeffecting SimCloth, BerconMetaBalls and all plugins in the vrayplugins folder
Error Loading DLLs
DLL <C:\Program Files\Autodesk\3ds Max 2010\plugins\simcloth3.dlm> failed to initialize.
Error code 126 - The specified module could not be found.
OK
error. I searched the forum and found that i should move the vray additional plugin line in the plugin.ini to the last position. I did that but it still occurs! I searched for another plugin.ini but the on in the max root is the only one i have in use.
