Failed
Out of the blue - restarted everything, and still the same issue.
Hey Bobby,
Most probably you hit the case where Windows disables the Cosmos autostart, for some reason. We have a potential fix to this, since version 2025.09.25.
  1. Do you have active cbservice.exe processes? Check in Task Manager:
  2. If not, then simply try starting Cosmos from the Start Menu shortcut. Restart Max.
  3. If it works, then check if autostart is enabled.
  4. Let me know your current Cosmos Browser version.
It started working by itself. Who knows.
