Faking DoF with Z-depth in frame buffer
Is it possible to use Z-depth render element as a mask for the sharpen/blur layer in VFB? I can’t see that as an option. Frustrating as it would be a great/cheap way to fake it without having to do it in post
No, but it would be nice.
Thanks for confirming. I thought I’d struck gold when thought of that, the kind of project I’m intending it for is definitely low production value, and a lot of people I work with insist on adding some general area blur in post, which I feel looks terrible.
@vray_team how can I request this as a feature?
We recently talked about it in an earlier post. Do a search and see what was discussed.
Is that not use the depth of field / physical camera options are for?
Or are you specifically wanting to do a cheap one post?
It simply takes time to render. More time to render. Using z-Depth pass in post is pretty efficient solution, like for faking volumetrics by camera distance in environments. you can even render multiple z-depth passes for different scenarios with one render.
But there are multiple “nice things” we could utilize using passes in the VFB though, which are right now possible in post (PS, Fusion, Nuke) only. I do not want to hijack this thread so… I just shut up here.
