Corona’s file overwrite warning is misbehaving after render settings reset. It doesn’t matter if the file was created with Corona stable or daily build, after render settings reset you are always getting overwrite warning, which is quite annoying.
Steps to reproduce: with daily build installed, create and save a new Max scene file, then reset Corona render settings and press save again - a window with overwrite warning will pop up.
