FastSSS2 prepass rate
I just realized I need some clearification about the prepass rate of the SSS2 mat because I never use it before :slight_smile:
Right now I’m working with an interior image 2560x1700 pix with IR+LC; IR min/max are -5/-3. I’ve only one SSS2 material; marble preset with some custom color.
The prepass rate is 1 but the number of effective prepass is 5; if i try to lower the rate number I can go down till 3 prepass but I can’t go lower.
From the help “A value of 0 means that the prepass will be at the final image resolution; a value of -1 means half the image resolution, and so on” so I’m expecting 1 prepass half resolution with prepass rate set to 1 but probably I misunderstood something. Any additional info about that?
