"FastSSS2 "scatter gi" issue
When I render my files, I have an error messages that appear (in red) in the Vray progress Window: " FastSSS2 “scatter gi” param is always “on” in V-Ray GPU ".
How can I fix this?
Thank you for your help
Michel
Hi @michel_baudbovy ,
This is just a warning message meaning that the Scatter GI parameter will be enabled by default on GPU mode (even if you haven’t enabled it yourself) in case you’re using Subsurface Scattering material. You can read more here.
In case you’re having any issues with the project itself - is it possible to send the files through our contact from so we can have a look? Much appreciated!
