Hello there!
I’m feeling that this is either bug or something wrong with my scene… I’m attempting to perform resimulation on my PheonixFD smoke setup, however, I’m running into the dreaded “Fatal error during simulation start! Please close other running applications, reduce the grid resolution and try again.” message.
My confusion here is that my base simulation is only 900,000 cells, and my workstation has 256GB of RAM. When running resimulation, it reaches roughly 19GB of RAM, before the error occurs. No other sizable applications run in the background during this process.
I’ve attached some various screenshots, I hope you’ll be able to deduce something from this ![]()
Currently using Windows 10, 3ds Max 2022, Vray 5, and the latest nightly build of PheonixFD (6th November 2021)
Thank you so much!
