Feature enhancement
Hello there !
The feature request in forum is locked to new topics.
It is not really a feature request, more an existing feature modification request.
The Pivot Placer popup would be easyer / faster to use if ypou could replace dropdown list by check / radio buttons
As we often use “center” for X & Y, and “minimum” for Z, it is long to select in lists…
Please see the small montage i’ve done in attached picture.
I think this one is quite simple to code, and will save lot of time for users.
Best regards.
If it’s any help, I use the SiNi software version of this (comes free when you install it, no purchase required), it’s a bit more logical in it’s efficiency.
I’m a Corona Renderer maximalist :wink:
Hehe, so by that definition you should use as many plug-ins as possible? :smiley:
For what you need Ill recommend to publish into Ideas Portal
Have you tried “Transform toolbox”
Its a 3ds Max tool, Ive never seen many people use it, it has a some very handy tools and very simple to use.
If youre interested Im attaching a simple script that place pivot into Base and Top of the object, since theres a “Center Pivot” that you can assign into keyboard shoprtcut
Hope it helps
Quad Pivots.ms (388 Bytes)
Just to note, as it says at the top of the locked Feature Request section, all Feature Requests should now be done via the Ideas Portal :smiley: Pop on over to https://chaoscorona.ideas.aha.io/ and post the idea there (or vote for it if someone has already posted it), if something remains as a feature request after the suggestions being shared here.
juste did post :
The vote system will not make this one in the top list, but again, it is a very fast & easy to code.
