Feature Request: More Photographic Camera Response & Tone Mapping in V-Ray
I would like to suggest improving the photographic response of the V-Ray Physical Camera and VFB Tone Mapping pipeline.
V-Ray is capable of producing extremely accurate lighting, materials and physically based rendering. However, even with carefully tuned lighting, the final image can sometimes lack the natural photographic appearance of a real camera.
The issue is not necessarily the quality of the rendering itself. The problem is how the rendered high-dynamic-range image is transformed into the final photographic image.
For architectural visualization, especially interior visualization, this has a major impact on the perceived realism of the final result.
The problem
Today, achieving a convincing photographic result often requires users to manually combine:
  • Exposure
  • White Balance
  • Highlight Burn
  • Contrast
  • Filmic/ACES workflows
  • LUTs
  • Curves
  • Color corrections
  • Camera settings
  • Additional VFB layers
Experienced users can achieve excellent results, but this creates an unnecessary technical barrier.
A user can create physically correct lighting and still receive an image that does not immediately feel like a photograph.
This is especially noticeable in interiors where there are:
  • bright windows;
  • dark furniture;
  • indirect daylight;
  • artificial lighting;
  • high dynamic range;
  • reflective materials;
  • strong differences between interior and exterior exposure.
Proposed solution
I suggest introducing a dedicated Photographic Camera Response / Photographic Tone Mapping system designed specifically to reproduce the visual characteristics of a modern real camera.
Instead of simply mapping HDR values to display values, the system could simulate the perceptual response of a photographic camera and photographic post-processing pipeline.
Possible controls
Photographic Response
A simple control from:
Natural → Photographic → Cinematic
with an advanced mode for professional users.
Highlight Roll-Off
A physically/photographically inspired highlight compression that smoothly transitions bright areas instead of producing harsh digital clipping.
Shadow Response
Natural shadow compression that preserves detail without making interiors look artificially flat.
Midtone Contrast
A photographic midtone response designed for architectural images.
Dynamic Range
A simple control for how much scene dynamic range is preserved in the final image.
Color Response
Natural photographic color response with controlled saturation and hue behavior.
White Balance
More realistic camera-style white balance behavior.
Exposure
Camera-like exposure behavior rather than simply multiplying image brightness.
A particularly important feature: Camera Profiles
It would be extremely useful to have several built-in photographic response profiles, for example:
  • Natural Digital Camera
  • Neutral Architectural Photography
  • Soft Interior Photography
  • High Dynamic Range Interior
  • Cinematic
  • Filmic
  • Editorial Architecture
These should work directly inside V-Ray without requiring an external LUT.
The goal is not to imitate a specific camera brand, but to provide predictable photographic image formation.
One-click photographic rendering
I believe V-Ray could benefit from a simple option such as:
Photographic Mode: ON
When enabled, V-Ray would automatically apply a carefully designed camera/tone-mapping response optimized for architectural photography.
This could dramatically reduce the amount of manual VFB tweaking required by users.
A professional user could still access all individual parameters through an Advanced mode.
Why this matters for V-Ray
V-Ray already has an exceptionally strong rendering engine.
The lighting can be physically accurate.
The materials can be extremely realistic.
The geometry can be highly detailed.
However, the final image is ultimately judged by its photographic appearance.
Improving the camera response and tone mapping would allow users to obtain a more convincing result with less technical adjustment.
This could make V-Ray more accessible to new users while simultaneously giving experienced artists a better starting point.
Architectural visualization use case
For example:
SketchUp scene
→ physically accurate V-Ray lighting
→ physically accurate materials
→ V-Ray Physical Camera
→ Photographic Camera Response
→ Photographic Tone Mapping
→ final image
The goal would be to make the final result immediately feel closer to a photograph taken with a real camera.
This would be particularly valuable for interior architectural visualization.
Why I believe this could attract more V-Ray users
One of the biggest advantages of a renderer is not only its raw rendering quality, but how quickly a user can achieve a beautiful result.
If V-Ray could provide:
“Excellent lighting + excellent materials + photographic image formation by default”
it would significantly improve the first impression of the renderer.
Users would spend less time fighting with tone mapping and more time designing.
This could also make V-Ray more attractive to architects and designers who are not technical rendering specialists.
Suggested philosophy
The goal should not be to make V-Ray less physically accurate.
Instead:
Physically accurate rendering → Photographically accurate image formation
The renderer should calculate the light physically, while the camera and tone-mapping system should transform that information into an image that behaves more like a real photograph.
I believe this would be one of the most valuable improvements V-Ray could make for architectural visualization.
Final suggestion
Please consider developing a dedicated Photographic Camera & Tone Mapping workflow for V-Ray, with a simple one-click photographic mode for beginners and a fully adjustable professional mode for advanced users.
V-Ray already has the rendering quality.
The next step could be making the final image look photographic with much less manual intervention.
I am in the Fuji ecosystem, and that is because of how it renders the image. It is all about color science. Lenses are also important. I invest in some high-quality lenses, and it makes a difference. Maybe Chaos can have difference lenses, with all the lens characteristics. I have two lens files that I use in the V-Ray camera, but they don’t do much. Maybe that can be developed. Film simulations would be nice. Just some thoughts.
There is already John Hable’s (Uncharted 2) and the Aces tonemappe for film response type looks in the VFB.
What others do you need?
You can apply others via OCIO also.
I’ve been going down an rabbit hole of film simulation of late - some of my more recent photos show some attempts.
Check them out
I am thinking more like Fuji’s film simulations. I mean, people buy into Fuji for those simulations. Maybe Chaos can create must have simulations that is unique to V-Ray.
There are various paper processing presets you can apply in v-ray to achieve some of that type of thing - it’s essentially what the fujifilm modes - fancy LUTS.
Saying that, I’d certainly like to see some more control over the VFB though. Maybe programmable post process filters or something. Although at that point I think it’s probably a case of there being software better suited for that.
I do use LUTs, but I guess I was thinking more camera stuff. I buy vintage lenses for the unique characteristics, so I am thinking along those lines.
Hi guys,
All of the idea shared in this thread are great.
It is true that you can do almost anything in the VFB already but it requires expertise.
We have introduced the Filters (color correction) presets a couple of versions back and the same infrastructure can be used for adding more advanced correction presets.
The lenses idea is also interesting and worth exploring.
I’ll open this topic for internal discussion.
Also, sharing ideas about what the ideal toolset for your workflows would be are quite valuable, so keep them coming.
Konstantin
