Although you can often disable Intel HD graphics in the bios, this is not always an option. It would be nice if you could specify the graphics card and not have to disable it in the BIOS. And/or always default to NVIDIA/Radeon if intel HD/UHD graphics are detected.
Thanks a lot for your input @Eelko_Van_der_Does . Just to make sure that you’re aware, there are options available for both NVIDIA / Radeon cards which allow the main GPU to be prioritized. Check out this article here for more info and how it’s done. To add, these solutions may not always work, but they should still be worth a try if you did not already.
Hi, yeah fully aware of those, plus other workarounds. It would just be nice to have it work without this. It has to be possible, I dont see any other apps crashing because there are multiple GPU’s even other rendering and/or 3D programs.
Just to make sure as this issue should not be limited to just Enscape, is there a chance the other applications you were using did not require a dedicated GPU, and some of them may have been using only the CPU / onboard graphics instead? That may not be the case so please do not get me wrong, it would just be good to know so that I can further forward and discuss this with our developers to see if there is anything we can do to improve upon this in the future.
Thank you again in advance.
