[feedback] BackBurner
D’ont why this happen but I have a window script wich open when I launch rendering via backburner.
Have you tried removing CoronaRenderer_InitScripts.ms from C:\Program Files\Autodesk\3ds Max 2017\scripts\Startup, and then re-installing Corona?
Hi, is this still an issue? Does it go away if you manually remove the script as Marcin suggested and then reinstall Corona?
i have the same problem
when i remove the file from the startup folder, the problem disappears, when reinstall corona - problem appeared again
is it a critical file?
what can be wrong when i remove the file from the folder
i would have say that the problem appeared after i install soulburn script pack and the error appears on 3ds max startup.
the following stroke appears before the error
just deleted soulburn script, problem still be the same
updating to 3ds max 2017.1 and installing sp2 and sp3 resolved the problem
