I have just tested this, and everything seems to be fine. Whether I display the lines in viewport, or hit render, there is no crash. I am using GrowFX 1.9.9 SP3 with a free tree preset found online.
Can you describe what exactly you did to trigger the crash?
Hey guys, I rendered a scene with grow FX yesterday and it went fine using the camera. If you can provide the scene and describe how to reproduce the bug I can give it a try on different nodes configuration. Make sure it’s not a RAM issue as I had some of that too.
lots of crashes here too, usually if the mesh hasnt already been built at render time. So if ‘manual update’ is on, then when you hit render max will freeze when corona starts parsing the scene.
this maybe be related to line mode as well. It seems if growfx hasnt already calculated the geometry, then corona will not allow it to do its jobs before corona starts rendering
Crashes when using the line display mode
We were not able to reproduce this yet. We need more details on this, so a good description and an example scene would be appreciated.
Freezing when “manual update” is enabled.
We have reproduced this successfully and will try to fix it together with Exlevel.
Currently the workaround is:
