Well this also has been asked before but I’d like to see Reflection/refraction override in globals to be two separate values as oppose to one.
Also, when selecting quasi for both gi bounces I’d like to se secondary boucne amount (like in brazil (view rate/ sec rate)) So that for primary bounce you could have 20 samples and for secondary 10. or something like that.
Another thing is in render globals, create a checkmark for area shadows override. I think that is essential.
Also…I’d like to see GI (on/off) moved to global switches.
Same goes to DR if one could enable disable dr and control it thru global switched.
Just a thought.
Thanks.
Well I see chaos team shows no interes in this…but..I’d still like some responce.
Well, almost all of your wishes has been wished before.
Maybe that’s the reason why nobody is answering.
I agree with most of them though. View rate/sec rate? Isn’t that in Brazil for the subdivisions of the GI in reflections/refractions? Please correct me if i’m wrong. GI and DR switches to globals? Yeah probably, the buttons should be an “instance” of those we already have then though. (linked buttons)
in brazil view rate is how many samples is shot on the first bounce, sec rate is howmany samples rebounce. In vray for primary bounce you get quasi say 10 samples, but how do you set 5 for secondary?
