Few newbie questions
Hello, would you, please, help me with some cases?
  1. Is it possible to preview displacement in material editor?
  2. Is it possible to link separate render settings to separate cameras?
  3. When I put some models featuring CoronaBitmap into my scene they lack their maps, so I show the way by the Bitmap/Photometric path editor. Now the ways are correct, but the materials still lack maps. It takes to reset each individual path to every map to make it work. Is where an easy solution?
    Thank you.
  1. i think no
  2. use cameraMod modifier at camera
  3. put all textures in children folder where main max file stored in what you are working
  1. No, that would kill the performance.
  2. Depends on what you mean by render settings. The new CoronaCam in 1.7 has all post-processing options plus more, but it does not let you control, for example, GIvsAA per camera.
  3. Try saving the scene. Then reset scene. Then load your scene again. Not sure, but I think this is a 3ds Max issue.
