Field of view in render versus Sketchup
SU: two point perspective or perspective, field of view 35 degree. Vray: 16:9 or match view port. All with simular result, and not the same view in vray render as in Sketchup viewport. What am I missing here ? In attache especially visible round center colum (fireplace not in render)
I suggest you to set vray settings to default and render, may be you changed some vray camera settings..
This doesn’t look like a field of view issue you are having, as those seem to match.
Your problem seems to be refraction from the glass. Are your windows a single surface with refraction turned on? If so, you should either make your windows have thickness with two surfaces to get correct refraction or check the thin-walled checkbox in the material’s refraction properties.
But render output is set to 16;9, so it is not supposed to be match.. But refraction may cause some problem it is true..
@kenancakir and @shelshok - you guys rock - thanks both suggestions seems to solve the issue. Merry Christmas from Denmark :slight_smile:
