After I import new objects into my scene my file fails to interactive render. It stays parsing for an endless amount of time and my total rays stay in the 1000s.
However, after I close and reopen the file, interactive rendering works like normal. It isnt after I merge or import a new object that the interactive rendering fails to parse the scene.
I dont know whats going on! This is very frustrating considering I am spending hours figuring out this problem rather than working on my projects. This has been happening since I updated to the latest Corona 12.
Does anyone else have similar scene parsing issues when using interactive rendering?
Try to reset your render settings to default from Corona Render Setup>Scene>general settings>reset settings
If the issue persists then try deleting your scene object by object and keep testing till you isolate the issue. it might be caused by corrupted geometry or hidden null objects.
Also try using Corona scene cleaner from Corona power tools and see if it helps.
Please, can you send over the scene you use, and the scene/object you import/merge, after which the IR will not start?
It can be related to the scene and to the imported objects. On simple scene, I found no issue when importing/merging objects while IR is running.
Thank you for your reply and troubleshooting options. I have attempted to clean the file via the corona power tools, specifically cleaning all retimers, and that seemed to do the trick. My file is much more responsive for now!
I appreciate your help so much!
Definitely. On simple files it works perfectly fine. After building a scene and merging many objects the file always gets less and less responsive. After clearing retimers the file seems to act much more responsive although if the problem persists i will have to send the file over as you mentioned. Thank you for your attention to my issue
