Hello guys,
I have an agent after crowd sim. I intend it to render it with motion blur. It works fine until I cache it.
The same with animated fur.
I expected that filecache essentially holds the same info as the cached node. Can I somehow get the motion blur to work?
I am using H19.383 and Vray 5.10.20 on Linux (PopOS).
Thanks,
Vojtech
Hello @woytha ,in order to get motion blur on moving cached meshes you need either to export whole animation in one abc/cache file, either to provide velocity attribute if you want to cache animation per frame. If this does not help, can you upload a simple scene of your scenario.
Hm, at the end it was something with camera… Not sure what, though. I ended up to recreated new camera with basically same settings and it works fine now (even without computed velocities!)
