Is there a way to get VRay to use some sort of filename token (like %scenename% or %filename, etc.) when writing out the VrImg (or EXR) files from the VFB FrameBuffer settings? I’d like to be able to always put those files into a folder based on the scenename. This is how we setup our normal renders, but that does not change the names written from the VFB FrameBuffer. We need to use these savers in order to do post process denoising withe the standalone tool.
Max doesn’t offer tokens of any type in paths, nor it supports literals or operation in spinners (unlike nigh anyone else.).
As Alex pointed out, you can do this easily enough via scripting, however.
“maxfilename”, “maxfilepath”, and such will provide you for the base for the names, and the property “.output_rawFileName” for the “renderers.current” object will be the string to write to.
You may use a simple UI to fill stuff in on button, or use a pre-render script to set it up automatically.
@_Lele
This is great. Thanks. Do you know the property name for the filename under the Separate Render Channels portion of the Frame Buffer Settings? We should be able to update that form our Net Rendering script.
My answer here is slightly longer than you’d have expected because the split bitmap saver isn’t a simple string like the raw saver, but a max save bitmap dialog, which requires some -odd- workaround.
There’s a nice thread about saving from the split here (with a macroscript, courtesy of @M.Max .).
You can inspect any object in max with the command “show()”
For example, with V-Ray set as renderer:
“Show renderers.current”
will print all the readable and writeable properties.
Feel free to poke me via email should you need more specifics.
