Filmic Tonemap Ruins Edges with Alpha
When Filmic Tonemap is on and applied to a saved EXR with an alpha channel the soft edges have a halo. It looks like the Tonemap applies to the RGB data without first properly un-multiplying the alpha.
You can especially see this is soft focus areas when using DOF.
This makes it kind of useless here. We are running a stable nightly from about 2-4 weeks ago. I can find the actual version of it matters.
Data out of V-Ray is not premultiplied so it doesn’t need any unpremultiplying. Overall what you describe seems like the one described here:
Yavor
Yes, similar if not the same issue.
It has the appearance similar to the alpha multiplication issue I mention, even though, as you say, VRay isn’t premultiplied directly.
Is there a fix in the stable branch? I think you said it was identified in the other thread.
Thanks.
As Aleksandar explained here https://forums.chaosgroup.com/forum/…06#post1092706 - no issue to fix.
