filtering for pal
I´m strugling whith renderings for pal resolution. Does someone know a good filter for pal resolution?
I´m having a very detailed bacground and its hard avoide flimer whithout bluring it to much.
/Daniel
i usually put a small vertical blur to the rendering in after effects.
this stops the flimmering on a tv
I have tryed to ad gausian blur in ae not only vertical but in my experience you have to blur it quite a bit to get ryd of the flime. I´l try it.
Thanx
Daniel
We usually use a 0.6-0.8 vertical blur in AE, tammo has right, but most of the cases can’t avoid field rendering. Some times the reelsmart motion blur is a great godsend too!
Palee
What about the different filters in max? Whitch one do you recomend? To me the areafilter looks best.
/D
IMHO these different filters are needed in the very few cases, some times I use Mitchell-Netravali, but when you work in the broadcast industry, the field rendering, the blurs, noises will hide the AA failures. Furthermore in this kind of works time is always a BIG problem :frowning: ; these filters increase the rendertime slightly.
But if you mind, in the MAX help you can find a pretty detailed description about how filters work.
Palee
thanks to you all.
/D
