final render gets colored dots out of nowhere! help pls
I’m fairly new to the visuals game, using 3ds max 2021 with vray5… sorry for this rookie’s error I guess
while rendering this final image, these colored dots decided to appear, and I have no clue as to why (see attached - around the kitchen windows & on the tree outside the living room)
I’ve set the light cache subdivs to 2500, and the vray settings - min subdivs 2 and max at 80. noise threshold of 0.005… rendering with brute force as primary.
are any of these settings the cause for these? could it be a material that is causing this?
I’m under the impression that the higher the values - the more precise and clean the image will be… I guess not?
thank you so much for your help!!
Hmmm, I’ve had a few of those, much worse than yours. And also on glass / reflections…
The log may be throwing a descriptive warning.
If not, feel free to send me the offending scene, and i’ll take a look.
You too, @JezUK , if you so wish.
My mail is in the signature, NDA is implicit, but we can sign one if needs be.
