Find out VRay version used in file
Is it possible to find out which Version of Vray was used to last save the file ? I have an assignment where the client is handing off files which were being worked up on by someone else & he explicitly wants me to use the same Version of VRay as the previous person did. Im on 3.1, so is there a way I can look for the version / build within the files they have sent me ? (Apologies in advance if this is a n00b question)
Thanks, :slight_smile:
If you run a file through the 3dsmaxcmd.exe command, it will print the version of the renderer that was used.
Thanks Vlado :slight_smile:
