Finding maps in new location.
Hi guys,ive just installed a second HHD to store all maps/models,work and so on..and for easier network rendering.
Ive re-configured paths for all map folders,so everthing opens fine with there correct map paths.
Except for about 500 plant models that contain the maps within the plant model folder,so when i open a plant model it still looks in the old location :x
Is there an easy way to fix this?
Or is it the hard way of opening every model and editing the material,or typing every folder into the configure paths list?
cheers.
You can try using the following:
1 Utilities (The Hammer Icon) - More - Bitmap/Photometric Path
2 Down click the - Edit Resources - Select Missing Files
#3 Browse the New Path - Use Path
4 Save…
That should work !
Best Regards,
nikki Candelero
cheers Candelero,ill give it a go.
works a treat cheers :slight_smile:
