Fire Flies and sky in Window
Hi
I have an issue with small white specks in the image at the meeting of ceiling and wall.
I am not getting any difference to the sky portal in the window, and the light outside is all white.
How do i get the image outside the window show?
Thank you.
Phil
Read these articles first, please:
https://coronarenderer.freshdesk.com/support/solutions/articles/5000516209-i-can-see-noise-in-the-corners-of-my-scene-
https://coronarenderer.freshdesk.com/support/solutions/articles/5000515605-how-to-create-background-material-in-corona-
Yup, most probably no thickness.
Btw, isn’t this improved in the newest builds? Got to check that.
I didn’t have this issue in very long time (but it was very common in alpha versions).
Thank you very much.
Yes the walls have no thickness.
And I will go through the tutorials.
Very much appreciated.
Phil
Easiest way would be to just slap on a shell modifier to the walls.
