Fireflies and render color difference
Getting some fireflies, tried some LMS and denoise setting… but no luck… did till 75 passes. any other setting to see…?
  • seeing some render view difference, in PS its darker.
  • Material preview and view port not updating texture when Reload Image.
Thanks.
The fireflies or area that need refinement can be relatively quickly cleaned with the render region. I sometimes use it at a small size which works very fast and almost feels like a brush when dragged around.
The difference in color mostly stems from a different color space that you used in photoshop. In what format have you saved the image?
I will try render region.
I saved simple jpg… no multi-pass or or any VFB filter.
ok, this should solve the problem:
https://coronarenderer.freshdesk.com/support/solutions/articles/12000020988-understanding-srgb-gamma-color-values
and
