I’m having issues with fireflies artifact in Vray 3.0 for Maya. Light mesh is @ 160 subdivs & 200 subdivs on material. For image sampler I am using Adaptive min = 1, max = 25, and threshold @ 0.005.
Any ideas on what I am doing wrong and/or how to get rid of?
@ bigbossfr - I did try max ray intensity at 10 but saw no noticeable difference so I didn’t bother lowering the value.
@ vlado - I eventually fixed the artifacts in post, but it would still be good to know what is causing the issue. I am sure it’s user error. I will try to get that portion of the scene to you when I get a chance.
Now that project is over and client is happy, I decided to go back in and run some more tests to see if I can find the cause. Strangely, I am not getting the rendering artifacts anymore. At first I thought it might be a batch render bug (since tests in VFB were fine) but ran it again with no issues. Very weird.
Anyway, I will never know what caused my initial problems. Seems these kind of things always pop up in the middle of production.
