Hi guys,
Here are 2 more fireplace visuals that I have done recently. Let me know what you guys think of them.
Cheers !
HI! Great work! I liked it.
I love the way you make carpets (and everything else, xD). Nice work!.
Materials are spot on, great work
Hi eduard…very realistic renders…i love your renders always…you have very good command on materials and shaders..cheers.
Btw how you did both carpets, if you don’t mind can you share your carpets workflow here.
extremly good, again! exterior is 3d or photo?
good job on these images man. they look photoreal thumbs up!
Great work Ed ![]()
Big fan of your work!! Photo real renderings! Would you mind sharing your fabric materials ?
Thanks!
Congrats!! Well done Renders !!
Hi guys, thanks a lot for your comments and glad that you enjoy them.
Image Box Studio International Both of the carpets are simply done with good diffuse and bump maps, no displacement or multiscatter.
hrvojezg00 The exterior is a photo.
sumeetgupta The fabrics are pretty much created in a similar way to the one that I described in this thread (https://forum.corona-renderer.com/index.php/topic,4031.0.html) just changed some settings since they were closer to the camera.
so only environment lighting?
Hi …i tried to make carpet like yours with the help of your forum topic but the result was not good. i really want to understand your carpet workflow. if is it possible for you, may you please share your only carpet workflow max file included textures here?
It’s fantastic like always Eduardo ! (is that UK client btw.. ?)
One suggestion/question: I see the reflection in first image in glass as unnaturally strong. Is still result of you rendering against black background ?
If yes, I recently found that I first overlay white in Photoshop from alpha channel mask, flatten, than use alpha mask again, so I get both benefits,
clean AA with no outline from black background, but correct intensity of speculars in refractive surfaces.
But if it’s intent, then sorry ! Just looks like issue I dealt with recently.
Amazing Eduard!
Congratulations!
Thanks again guys for your comments !
Hey Juraj, yes it’s still that client from London (some jobs just keep on dragging on, arghh) . As far as those reflections go I remember that I did tinker with them in Photoshop a bit but I hadn’t rendered the still on black, well, sort of, I applied that bitmap in the Direct visibility override slot. I basically didn’t want to add the background in Photoshop and add the reflection pass on top of that as I would’ve gotten some AA issues, I noticed that even perfectly outlined black and white masks don’t always give perfect edges and that’s why I tend not to use them (on projects that have to be done in a hurry I still use it though ). I will try your method as well to see how it works !
Cheers !
Oh my god, you are incredible talent Eduard, it is absolutely amazing to what detail, photorealism and beauty you tighten every aspect of renderings. I am getting strong feeling that 3D artists based in UK are so good hah! Would you mind sharing your basic workflow? I mean mainly creating lighting (on white model first?), tweaking materials (first using hdri preview?).
Keep incredible quality ![]()
Jakub
Well done, congrats on this set, very beautiful renders!
Hi Jakub, thank you so much for your words, I’m glad you enjoy them. Actually I am a big fan of your renders too, especially the kitchen with the chromed island, love the lighting and shaders in that one. Well, as far as my lighting workflow goes I mostly use hdris and test them out when I start the scene so yes when everything is still white, after which I slowly start applying materials one by one, usually I start with the floor and larger sized elements. Also, I always try to keep my Exposure in corona at 0 and adjust the HDRI light to the preferred intensity and the same principle applies when I add artificial lights, this way I know the right intensity of every light. And that’s about it, I hope that helps, cheers !
Nice design & render!
