I have made my first postproduction of Corona render. My aim is to achieve not just the great renders, but effective postpros…I knows I must learn more and more, but…
If you have any observations, please writ me, I’ll be thankfull for that !
Sure…I have send the raw render, and here is my second playing with post.
I’d like to make a real photographic pictures, but for me now looks like a bit too much the “photographic”.
If you have any idea, please don’t hasitate to share.
If you want “real” photos, first - you should use realworld values of camera dof )) Maybe more bump on the carpet. (And check thickness). And the last one - some material looks not very realistic. For example - dark wood on the table and chairs and material of nightstand! Good luck to you!
Thanks your reply, about the DOF I know that’s not right. I did not use any rules for the distances. Or may I have a chance to use something easiest way to DOF’ distances? I mean ZDepth min&max ?
Now I learning the photographic, which I think an really important side of CG.
And I posted to links to great writing for materials and postproduction.
You may use target point of camera for setup dof distanse. Then you must watch focus distance in camera settings and enter this value in corona settings tab. (for a dof)
Ok, i have learnt photographic wee bit) And say. For first pic put target on cupboard (diaphragm 4 or 4.5 for example). lámpa.jpg .
Then second image : nearest corner of table or vase. And set diaphragm 5 or 6 or little bit more. main_PP ready.jpg
Better less than bigger diaphragm for start) Small values applicable for a macro.
Of course, real camera (daily builds have this modifier for a camera, and same settings) has got diaphragm, shutter speed and iso, white balance and other.
Thank you your advice, I’ll try it . I did not figured out, but this sound really good! But I don’t know that diaphragm…What it’s mean exactlly…I found something on WIKI, but that’s somaething else about the inner body…
