First commersial project with corona
Hello guys,
this is my first attempt to finish commercial project with corona v1.
I’ve worked on this 5 hours + render 6 hours on 1 pc. Somehow dof are bit messy and some materials (bed for example), but i’m satisfied with the lighting.
Don’t judge me too hard i am still beginner with corona )))
Cheers,
G.
Looks like the vertices need to be welded on one of the wood pieces, check the pic below. As you mentioned the materials could use some work. The chandeliers, i’m not sure if they are suppose to be glass or some type of metal? The chair fabric texture scale looks rather large.
Theres plenty of help on these forums on materials, just do a search and you likely find it. You could also head over to http://coronamaterials.com/ and download those to get a better idea on how material settings.
The white materials in your scene feel incredible bright too. What RGB values are you using for those?
