First Corona Renders
Hi guys,
here are my first renders I did in Corona. I’m happy with the result, anyway I would like to hear from you, if you like it or not and if not then please tell me what to improve to make my renders better. Any critics and comments are more then welcome.
Thanks for your help Coronauts.
Roman
Hi, the images are really great, especially for some of the first works with Corona, but here are my notes:
-they seem to be a bit over-processed, especially in terms of sharpening
-the floor is too shiny (“wet floor effect”)
-a bit longer render time would probably help get rid of noise and hard edges, although making the floor less shiny and restraining from sharpening the image in post would probably remove noise
Also here are some tips for optimizing render times if you need it:
https://coronarenderer.freshdesk.com/support/solutions/articles/5000516731
Thanks for your reply and tips, Maru.
I’ll try to avoid those mistakes in my next work…or I will place “Wet floor sign” on the floor :smiley:
