First exterior test
Dear Coroner´s, last weekend i made some exterior test, when i used PT+HD+ HDRI and Sun. Render time was around 1 hour.
Comment´s and critics are welcome :-}
The correct term is “Coronauts” :smiley:
Thank you for explanation :-}
Nice to look at. I think you could work on your textures and post-processing because shadows seem to be a little too dark. You can use camera correction modifier to straighten vertical lines.
Miłe dla oka rendery. Myślę że można by popracować nad teksturami i post-processingiem bo cienie wydają się trochę zbyt czarne. Możesz zastosować modyfikator camera correction żeby wyprostować linie pionowe. :smiley:
It was very fast render and test, i used textures from my old library, in the future i will use better resolution and i check camera correction. Thank you Maru
