Can you please give some feedback. Thank you.
Re: First Kitchen Render
sir very nice & clean render, only 1 comment put ambience outside the window it would be better. congrats sir, can you share your model + visopt settings, nice counter top & cooking ranged if possible only =)
hello…
its a great start… but i have some comments.
On a positive your lighting seems good, especially in the last image.
Modelling seems pretty good, the wood texture on the cupboards makes it hard to appreciate but looks pretty solid
On the negative -
Your floor is very smooth which is good but for my taste its a little too reflective… not a great deal but too much never the less
You texture on the worktops is clearly tiling
The cupboard wood texture is horrid. I can understand what effect your going for and i love kitchens like that, but the use of the texture really ruins the image that you’ve clearly put a lot of effort into. Firstly it tiles to obviously. Is the extractor oven the hob really going to be made from the same wood…? Changing that to the same metal as the oven will help. The position of the texture on the cupboards is all too perfect, by that I mean the texture lines up on the door panels and kick strip below, along with the drawer door above. You’ve not done it on the wall cupboards which is better. It needs ‘mixing up’ basically.
And finally just add some more items so it looks lived in… at the moment it looks like empty house thats just been built… all renders should have ‘life’ to them!
Hope this is help, but for a first go you’ve done well!
Kind Regards
you cant see the division between doors/drawers and the rest of the cabinets.
either you separate them like one millimeter in each side from the cabinet, or you can round the corner (or bevel) (about 1 millimeter) in the edges of drawers/doors vs cabinets… or you can make doors and drawers a few millimeters more “inside” or “out” of the cabinets.
any of these methods will already make it easier to see the edges of doors/drawers.
Another thing that can be done is rotate/move the textures of each drawer/door, after all, in real life, they come from different parts of the wood and WONT seamlessly match the rest of the cabinet.
Thank you all for your replies. I hated the texture of the cabinets from the beginning so I have changed them since this photo.
What do you mean by ambient outside?
To answer your question about the hood being wood, yes it is… I have no idea why and that was the first question that I asked. lol
Thank you for all the comments!
the cabinette textures are really nice, just change the kick material to a plain black kick base and make the range hood a silver like ur stove. i like the style, you just need a better camera angle and you should be fine, great work!
can you please tell me what are the reflection settings of the floor, and also where did you find that texture?
