First look at Corona
Hi, my first post here… And my first run with corona and interior renderings.. Lit with only HDRi environment. PT+HDcache
How you can use fur???
Magic :wink: …it’s corona scatter (1 strand 160 000 times over 2 carpets)
You mean highlight burn? I see no white multiplier, only intensity multiplier..
Actually, the raw .exr output wasn’t having any overbright areas :smiley: I did this in post, I kinda wanted to have some little overexposed areas. Is it so bad? I’m gonna take a look at different monitors…
Or you could just save your image to .hdr and do magic in photoshop.
Well I just said I’m using .exr output (full float 32Bit)
Fantastic result ! but i agree for the burning areas, the post processing can hadle that easely or hdri like said above.
nevermind… I will add other views without overbright areas, once rendered but I have a problem. I can’t seem to find a good balance in quality/time with the PT sampling value. This first one was 128PT samples and it took about 2hrs to render in 1080p (the picture here was downscaled to 720p). I think it’s not that bad for an old q6600, however I believe it can do better. I raised the PT to 256 but after 20 min or so I could not see any change in a refresh when updating. So does it make any sense to go higher than suggested max of 64 or should I even use lower values for a situation like this?(tried default 16 but it was very noisy even after an hour)… I’m rendering now with 32 it does look good after 20min. I’ll see what I get in an hour. And yeah, another question how big impact does changing the update interval value have? I now it’s good to raise it when rendering above 2k res. but does it give any significant speed gain or it’s not a big deal to have it at def. 1000ms?
Oh, thanks. It makes much more sense now. The light samples multiplier in render settings does affect even the environment HDRI sampling and emission of materials or it’s just for regular light objects? Thanks again for the explanation.
Its for all light sources (hdr, geometry, coronalights). Corona does not differentiate between those
well that sounds… fucking AWESOME… If concurrent renderers won’t get some really great improvements in their next releases, then I can already see Corona making them run for their money LOL…
Corona Scatter??? Where i find this??
command panel - “standard primitives” open the rollout change it to corona and there is CScatter Corona fractal and proxy
oh god, of course, i really really thanx
Testing some different cameras…
