First post, just a simple exterior.
C and C welcome.
C and C welcome.
nice!
the building is well integrated into the bg photo, although the angle is a bit wierd…
do you mind sharing some info on the lights setup / what comping methods you used?
minor crits;
not sure if the sun angle is exactly right.
if you look at the building a bit further down the street it has a much steeper angle where the sun hits the side of the adjacent building.
The leaves on the tree to the top right of the image look seperated from the branches.
Tiling is quite noticable on the brick.
Well spotted on the sunlight, client never saw that!
Brick and tree on right OK at full size though.
One direct light for sun only, post prod in Photoshop
for glass etc.
BG is 3 pix comped together to get view, so building is slightly
distorted, par for the course though, what what old bean.
looking good - only things I would comment on are the tiling of the brick and the reflection of the tree to the left glass - I would suggest darkening it down for more contrast.
