First renders - Paris apartment early previews
I’ve the same problem with Corona Frame butter. With res > 3K or 4K it eats a lot of RAM (too much). Ondra knows this and it has to rebuilt the entire FB. You car reduce the int res to 1, but you could have some problem with bright edges (like with Color mapping on in VRay) . Int res = 1 double the real resolution inside corona. This is why it eats so much RAM.
Yes, thanks Michal ! Corona is indeed quite what I did not expect.
Hi Cecofuli, saw your frustration in Chaos forum “All about noise thread”. I’ve re-read that thread 5 times back and forth in my own pursuit of ultimate brute force settings for high-end interiors.
I’m very much enjoying the in-render DOF, I think I can finally keep it ticked-on constantly. I had some exteriors tests already too, and it was breeze ! But I expected that, even Maxwell was very fast in exteriors. Funny thing, I noticed the converter even switched VrayDirt for CoronaAO, which isn’t yet much advanced, but did some trick too ! Nice. Now I’ll wait for normal maps.
I like that material is so “regular”, and seems closer to ArchDesign shader (translucency and corners, nice). I could not stand Maxwell materials, I did not understand single value, everything seemed like complete science. Absolutely bothersome, I had trouble initially even coming up with specular mat. I like simple things. The simpler, the better.
That’s unfortunately true. I tried to do it the best way I could but since VRay is doing some things in non-explicit ways (fog, translucency) it’s not always possible to get good results (Arch&Design material was way easier to do).
I’m trying to convert all those third-party maps which would break the render (VrayDirt, VrayColor, …). Normal maps will be implemented when Alpha5 is released. Keymaster did implement a corona normal map in the daily builds already :smiley: .
I salute you for great effort :- ) Converter is literally deal-breaker for many people, me included. With the giant amount of assets I have on my drives, last thing I want is start from scratch.
Keymaster already invited me for daily build, and I will do so at the end of this week.
Last image needs burn value to be set to 6+ (im always using 99 ). Try.
Sorry sorry, I digress :- ) Burnt, and low-light is requested by client, and I love strong burnouts too :- ) They bring life.
Here is example of her work and photography. But maybe I overdid it ? It’s tough balance..
That said, I will try it. But since the output is fully unclamped, is there reason not to do it in post ? I do not liked colormapping in Vray much, and kept it fully linear with adaptation to adjust light balance in MagicBullet.
Thank you Michal for advice
The burn is very controversial thing and is a lot taste-based. I don’t want to excuse myself it’s indeed too much :- D But I do I prefer it a lot, even if it comes across wrong for quite most people.
My biggest inspiration is Yellows photography. http://yellows.dk/ It’s one of the most high-end scandinavian interior photographers, and I am very jealous of their work and would love to attain similar level one day in digital domain.
[upload|rnyUkSc05sjyMRAJUMg66w==]
Just trying to explain :- D All in good faith, I do write down the opinions :- ) And value them guys
Rawa, mine is modified in post too :- ) It’s not that overburn in Corona Framebuffer. I have difuse glow, and strong softlight in PS.
Sure ! Which ones do you have in mind ? Any help there is greatly appreciated. I do try to add subtle glows to highlights, but for other things, I am bit lost.
There is no reason why to do post in Corona other than it is easier and you get interactive preview during rendering. But sometimes you would need to render to higher resolution and downsize after tone mapping to simulate the effect of internal res 2.
Thank you for answer, I see about the AA.
Great advice guys, it’s cool such small forum is busy and not left ignored by devs. But now go back to work :- ) ! I am doing too much discussing again. Need to model stuff and go back to enjoyable part again on wednesday.
Rawa: Nice !! Thanks. I am always afraid not to overdo glows, what settings did you use if I can ask ? Esp. since you were able to do so in tonemapped jpeg !
I guess I’ve become too lazy with MagicBullet as my only solution. I wish too much for one-click solutions, and dread manual post.
Something funny is going on with I presume bump maps. Occasionally, checker patterns shows on some objects with mentioned material. Checker pattern even shows in Material editor behind ball, but I guess this isn’t connected, just saying because I am confused what this can come from :- ).
What is the consensus on material filtering ? I have ALL my bitmaps set on Unfiltered, and 0.1. This gave me the best results in Vray, but does it apply here too ? I am mostly concerned about the “unfiltered” part.
The checkerboard pattern can be seen on black leather chair on right.
On second note, I’ve experienced bit more with HDCache, and it’s indeed lightingly fast : ) Very nice, but for this project, I’ll stick with PT+PT.
Nice render, but you can use WIP section tbh. :wink:
ps : i see squared pattern on chair ? Probably strong bump ?
Yes, that’s what I asked, but I use quite lowish number, never higher than 0.02 (I hope is equal to 2 in Vray numbers). Whad do you think about filtering ?
You might be right about the WIP, didn’t occured to me it’s here. Usually no one uses it, but now I see it’s up higher from this section Well.. . I think I’ll stop now and just finish the project as is :- ). Cheers
I had this “squre-noise-pattern” issue on some models from designconnected. I didnt realise why its there and how i should remove it.
Try to switch off bump and check, if its there. It might be bug related to geometry.
Good you mention that, because that chair is from DesignConnected :- ) and it doesn’t exactly has amazing UVWs. Funny thing is, even at same image, it doesn’t show from all angles, it started happening randomly. Reading some advice here, I switched the material to filtering on, with Summer Area. But I also changed bitmap…so not exactly debug process :- ( But no time for that now..
Hi i’m marco i notice that your work is the of Beltrand Benoit Baron Haussmann apartement, can you tell me where you have buy it?
thanks
Marco
http://bertrand-benoit.com/blog/2013/05/12/baron-haussmann/
Sure, from his Turbosquid space :- ) Absolutely steal deal. I bought the fireplace and facade. Here you go http://www.turbosquid.com/Search/Artists/BBB3viz?referral=BBB3viz
He even uploaded me the facade because I nicely asked. He’s great guy
(Disclaimer for future readers, DO NOT, even try to ask me for “share/exchange/whatever” if that is your intention :- ) cheers )
dont have much time, so just briefly:
  • checker pattern in material editor BEHIND balls is a feature, you can disable it with that show-checker-background button in max UI
  • checker pattern in scene with BUMP occured in some older builds and is fixed now. Update your build to fix it!
  • you will get the best results possible with as low filtering as possible, provided you don’t care about time. You can globally disable filtering in devel/debug tab of corona settings (the tab has to be turned on in the about tab), BUT
  • you absolutely MUST have filtering enabled for bump to work correctly! Due to the fundamental nature of the bump algorithm it requires reasonable filtering (value around 1, NOT 0.01). You can use displacement* and/or normal mapping without filtering, but NOT bump mapping!
  • all of the above assumes you use the latest version that has the filtering fixed. If you still experience some problems with filtering there, report it as a bug.
  • actually, filtering is ignored for displacement mapping
