first upload here
Hi! This is my first image upload here - one of my projects. C&C are welcome.
http://img221.imageshack.us/img221/4390/sim16mg.jpg
:smile:
Very nice, grass and foilage look great as does the glass, the roof tiles are bouncing a little too much colour onto the white, you can control this by setting the generate GI from the object settings in the render dialog,
Wouldnt the tiles be going the other way, i.e. the bottom of one tile should overlap the top of the tile immediately beneath it? if you used a Vray Disp i’m sure a negative value woudl correct (or positive if you used negative )
also maybe chamfer the edges of the stone columns
whats your lighting setup?
Good work,
Regards,
TOm
hi finalg,
welcome :smile: ,
great image! very nice lightning.
the DOF is a bit too extreme. but maybe a personal question.
Kinky :lol: love the landscape, glass reflections are very nice, so are the trees. What did fou use for your foliage, xfrog :?:
steve
It looks great overall. I like the DOF and the bloom. What’s your lighting setup if you don’t mind us asking.
Hi
10x to all!
Trees & shrubs are Onyx, grass - vraydisplacement…
vray 1.47.03
Primary bounces - irmap - 1.0
Sec. bounces - lcache - 0.8
irmap - medium preset
lcache 1500 subdivs, sample size 0.3cm
use lcache for glossy - on
vray skylight - 1.0, colour 218, 229, 255
spherical environment map for reflections
Vray light - multiplier 3, colour 255, 243, 227
colormapping - intensity exponential: dark- 1.0, bright 1.0
Think that is for lighting… :smile:
Very nice image. I like the warm, soft feeling of the render - but - I think less dof would make it perfect. Oh, and agree with tom182 about the roof tiles.
really nice image,
would you be good enough to share your reflections environment map? I love those crisp reflections… or are they or the tree geometry?
Sweet sweet render!!
Having the 3d trees in the backgroud adds a nice touch.
Well done
Look forward to seeing more of your posts!
2 sv
Reflections are trees geometry + gradient ramp for sky background
Cheers
// DOF - the client wants to be like this //
Looks very nice. As sead before, the the trees/grass are outstanding !
I use Onyx trees in combination with vrayproxys but for the texture of the leaves I can use only one texture becouse its one object. It seams every leaf on your tree has diferent shade, how did you achive that. Or maybe I am wrong.
2 kpavlov
Try to use color correct - http://www.cuneytozdas.com/software/3dsmax/ColorCorrect/cc\_install\_v3.0.3.6.exe for leaves. This is last material in multisubobject material for entire tree.
Don`t forget to keep old material when asked!
Then You can play with settings in color correct for your needs.
Same are my trees here.
Cheers
Huuuummmm Really nice !!!
