It would be nice to have a button on the frame buffer. I like it when I am testing things, but I need to turn it off for the final. Not a big deal, it would just be nice.
It would be great if there was a button to toggle this feature in the VFB. Also, it would be nice to have a scalar factor for users that work on 4k monitors. For example, to be able to do 1/2x or 1/4x the window size so when you full screen the VFB on a 4k monitor it is not rendering the full resolution of the screen but rather a 1/2 or 1/4 version. Or another option would be to manually scale the window then a “lock” button to then lock it to that resolution so when you maximize the window it will not change pixel dimensions. this can obviously be done using the unchecked fit resolution button, however it would be nice to do this interactively without needing to stop the IPR.
Just realized the presets auto update the VFB…my bad!
Would love to have such a button, as glorybound suggested .
Smoother zoom in and out with fit to vfb would be great (I remember it has been requested before in this section)
Fit to VFB exists but only when using IPR and yes a similar feature, but one that can be switched on / off, rather than having to stop and deselect it, then re-render, would be nice.
