is there some way how fo fit image to window via command line? Because resize_window_to_fit or reset_pan_and_zoom its something else and I was not able to fing command for this. Also Reset/Fit to window canot be mapped to hotkey which is sad ![]()
--reset_pan_and_zoom does exactly the same as the “Reset/Fit to Window” option in the right-click menu.
It’s a toggle, though, maybe this is the confusing part. Upon executing it, it will either “reset” or “fit” depending on what the current state is.
I’m guessing you need to make the image always “fit” whenever you launch a new instance, correct?
Yes correct alway fit. But how to do it with togle? Because it never works for me correctly.
It’s hard to do this with a toggle, because you can’t force the state you need.
I’ll make a note to add a flag that can force a specific state.
Great thanks. I hope for quick fix.
Hi is there some time estimation when this could be fixed? I’m really looking forward to thix ![]()
Any news here?
At least it could fit to window by default. I dont need the commag line access.
Noone else doesn’t have a problem with this? Its super anoying to always fit manualy. And besides hotkey doesn’t work…
Yeah, having the preference be remembered would be nice.
