Can we please fix the issue where if i change my rhino’s viewport aspect ratio, it changes the output image from Enscape as well, even though the resolutions are already set and camera never changes spot.
We as designers always do some level of post processing after we get exported view, it is critical for each export to match spot on, so if I were to change an element in the render, I won’t have to change everything in my post processing file to match it.
Also this hinders working in a group, where multiple designers may all take passes at this one image, but all the exports from different computer should be identical regardless of the rhino view port ratio or monitor sizes.
What we see should only be affected by the camera and aspect ratio, not by the working window/ viewport.
