Anyone knows how to make the debug mode of a custom VOP HDA work with V-Ray?
Best,
David.
Hey David,
Sounds like something we need to investidate on our end. I assume it is the Subnet Output VOP that you would want to be evaluated if the debug flag is enabled on the parent HDA ?
Best regards!
Hey, yes the subnet output would be the target so shaders can be debug at that point.
I was looking online and couldn’t really find anything about VOPs debugging, besides some post of other people looking and not getting any answer ![]()
Wishlist then, debugging for custom VOP HDAs.
Best,
David.
Haha, same on my end - I was hoping it is possible to expose the debug flag on one of child nodes.
Regardless, hopefully it’s just a matter of registering the Subnet Output VOP somewhere in our code. I’ll update you once I get info from the devs.
Best regards!
Thanks, looking forward to it.
Hey David,
This is now implemented in the latest nightly builds. There’s a crash when deleting the debugged HDA - I’ll inform you once we fix that as well.
Best regards!
Hi @Gosho.Genchev ,
Doesn’t seem to be working. When I debug this node I should be seeing color, as the color correction after it is set to 0 saturation.
V-Ray for Houdini number:12440 hash:557fae6 from 13 Mar 2021 02:57 (build number:12440)
V-Ray Core 4.30.03 [14fe1e94] from 12 Feb 2021
EDIT: This seems to work in the V-Ray 5 builds, so the problem only persists in Next.
Best,
David.
Hey David,
The crash is also resolved now. I will check the V-Ray Next issue and inform the dev team.
Best regards!
