(Fixed) [ HOU-2128 ] Frame sequence in lights
I’m trying to use a fram sequence in a mesh light and it doesn’t seem to work. I tried using $F and $F4 and it alwasys returns frame 0001 instead of the frame I’m currently at. I can see it vray throwing an error in the log window trying to load frame 0001 and in the expression it grabs the correct frame.
At frame 1048, using $F4, in the light UI you can see it evaluated correctly as frame 1048 but in the vray log window it says 0001:
Best,
David.
Altough no reply was given, I’m assuming this issue is fixed, correct?
Just tried it using the latest nightly.
Best,
David.
Yes, it should work now.
Awesome, thanks :smile:
