(Fixed) [ HOU-2226 ] Physical Sun disappearing
I seem to be having a weird issue here the Physical Sun disapears - one render it is there, the next it is gone. As you can see from the screenshot it is enabled, but missing checkboxes in the light lister.
Anyone else had this issue or discovered a workaround/solution?
I am using Vray Next in Houdini 18.566 on Windows 10.
I’ve never encountered such an issue. Stranger still is the fact that some toggles are missing in the Light Lister.
Does anything show up in the Houdini console when you open the lister with the issue present ?
Best regards!
I had another look at this scene and nothing would come up in the console. In the end I rebuilt the scene and haven’t seen the issue again.
Bizzare … I’m glad you figured out a solution but if the problem pops up again, please ping us.
Best regards!
