(Fixed) [HOU-2364] mutli id texture don't seem to work at all
mutli id texture don’t seem to work at all
I thought it would work as the multi sub in 3ds max Chaos Docs. there you can choose based on object or renderid and get a random value. If that’s not the way that node works i misunderstood.
Btw is there a way to take an integer id and convert it to a random float between 0 and 1?
Regards Alexis
Well, we don’t have a Random texture per se, but you can drop a Noise texture and plug an Explicit UV mapping into the UVW Gen slot.
The Explicit UVs do what the name implies - set the sampling coordinates to an explicit U/V value.
If you then plug your attribute into the sampled position, you should get a random piece of the noise for each attribute value.
If that is not what you were looking for, please ping me so we can try to think of something else.
I’ve attached the hip file here: https://drive.google.com/file/d/1WiDTjefSAkS1D2V7ZQrhc681mmPPyQmY/view?usp=sharing
Cheers!
For setting per geometry island variation with the multi ID texture, I’m assigning an integer value to every connected primitive using a “connectivity” node, then feeding that parameter to the multi id texture using a user integer/float. This works but it’s an additional step, would be nice to get an option in the multi id texture/material to do this, also with a seed option.
The radom node would just create a random number, you still need that random generator to run a loop through out all your primitives, connected geo, points, etc. If that random node have the option to create random values for specified condition, like Primitives or connected geo, that would be great.
Also what about random texture rotations per geometry island? :smile:
Best,
David.
There is an input/param in the named uvwgen for that.
@bdancer , of course ahahah, thanks that was so easy, works like a charm :smile:
Used the workflow that David explained above, with the connectivity node. Works nicely!
I have like 1000 wood blanks in this floor, and I have 18 wood textures for variation to assign to random islands. Works nicely!
Thanks for tips :slight_smile:
@Muhammed_Hamed , that’s a very good looking floor
This does not work on CUDA - Could this be fixed so this technique could be used in CPU + CPU, please. THanks
@hsz , you are correct, TexRandom is not supported on CUDA, but TexMulti should work.
Is this something that is planned to get into CUDA or not? I’ll try your suggestion and I’ll get back to you, thanks.
@hsz , I’ve added request about support for TexRandom on CUDA in our to do list and will inform you once is implemented. The number in our system is HOU-2364
Thank You! Appreciated
