( fixed ) [ HOU-2595 ] Camera Exposure set to "Exposure Value" has no effect on image
When the camera exposure mode is set to “Physical exposure” everything works as expected but in “Exposure value” mode the exposure value paramenter has no effect at all.
I am doing something wrong or this is a normal behaviour?
From my experience with vray for 3dsmax the exposure value mode should be a way to control de overall exposure of the image with just one parameter, isn’t it?
We have realised this too and it would be nice to able to use the “Exposure Value” instead for “Physical Exposure”
Regards Alexis
Hi guys, you are right, exposure value is always exported 13. The issue is reported.
Exposure Value is working in today`s builds of V-Ray 5.
Great! thank you for the quickly response
V-Ray for Houdini number:12941 hash:20a388e from 11 Jun 2021 02:05 (build number:12941)
V-Ray Core 5.10.20 [5322b47e] from 4 Jun 2021
maybe im too early but it didnt work with this build. Plus now the shutter speed in not greyed out anymore
Parameter name has changed, since phys. cam. settings are spare parms you’ll have to re-add camera properties manually.
yes that worked, thanks!
Hi. I though I have access to nightlies but I can’t see last versions. All I can see is stable versions:
How can I access to the latest nightlies versions?
