starting with the build from 2021 06 01 (core 5.10.20) ocio seems to be broken. using ocio in the imagefile node for example results in wrong colors and extreme render times.
Same issue, have to manually convert all texture files to be able to use them.
Hi, are there any updates on this, because this issue made it into update 1 which makes working with ocio/aces impossible.
Dear ronald_a & miro.digital, hello.
I was able to reproduce the delay when OCIO is enabled in the imageFile node.
It is now logged in our system, thank you!
About the color differences - a demo file will be highly appreciated.
I have tested many scenarios and combinations (Render Settings / imageFile / VFB), so perhaps there is something in the setup.
Let’s unravel this.
Waiting for your answer.
TS
The slowdown is fixed in the nightlies. Sorry for the inconvenience.
@bdancer awesome!
