(fixed)[HOU-2954]Camera Motionblur 19.0.445 ?
I am trying to render a moving camera with motion blur.
If I move the camera, no motionblur.
If I move the geometry, I do get motionblur.
I attached a simple test scene.
Motionblur is turned on in the physical camera atribute as well as in the vray renderer.
mb_tester.zip
THX in advance.
Cheers Christian
mb_tester.zip (44.3 KB)
Hello @bumba , looks like camera motion blur is broken since January 19. I’ve reported the problem and will inform you when it is fixed. Meanwhile you could use a build before Januray 19 were camera moblur is working.
Should work in next nightly.
Yes, it does, thanks :slight_smile:
